04 YFZ 450 cutting out
Old Sep 5, 2006 | 05:52 PM
Dut's Avatar
Dut
Default 04 YFZ 450 cutting out
my yfz is cutting out at 3/4 throttle, in all gears, i have a pro-circuit slip on pipe, air filter lid is on, dynojet kit with a 136 main, i've tried changing coil, running on reserve, i'm kind of at a loss, can anyone offer some words of wisdom
thanks
Old Sep 5, 2006 | 06:03 PM
z250rida's Avatar
is ur airbox clean, do u have an aftermarket filter, is ur filter clean????????
Old Sep 5, 2006 | 08:48 PM
Dut's Avatar
Dut
stock air filter and the box is pretty clean, i cleaned it last weekend, and still same problem???
Old Sep 6, 2006 | 10:05 AM
FastbansheeandKodiak's Avatar
Your main jet is to small, try a 150 or 155 just as a quess not knowing your elevation and temp but the main jet affects from 3/4 throttle and up.
Old Sep 6, 2006 | 05:02 PM
JLsparky7's Avatar
Thats what i was thinking. Your main sounds way small.
Old Sep 6, 2006 | 05:26 PM
z250rida's Avatar
check if ur jets are clean
Old Sep 6, 2006 | 05:28 PM
z250rida's Avatar
u might also wanna get a aftermarket air filter it will give u more power since u already have the pipe and jets ur better off with a air filter like k and n
Old Sep 6, 2006 | 11:16 PM
nomoyfz's Avatar
lose the box lid put a165 main jet in ,you may have to turn your idle down a hair ,but it should run great. since you have a slipon you should not have to worry about moving the clip on the needle. If you have any questions feel free to ask.
Old Sep 8, 2006 | 01:26 PM
Dut's Avatar
Dut
thanks man
Beeline08
Nov 11, 2016 04:00 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Elkaholic
Sep 6, 2015 02:44 PM
