grizzly speedometer problem
Old Sep 5, 2006 | 07:43 PM
wheelzy's Avatar
Default grizzly speedometer problem
my 03 grizzly speedometer is way off does anyone know what the problem could be? it is reading much higher then the speed it is traveling.
Old Sep 5, 2006 | 07:46 PM
greenscreaminv's Avatar
are the tires your running the same size that came on it originally?
Old Sep 5, 2006 | 08:01 PM
squeege's Avatar
would you be reading kmh or mph
Old Sep 5, 2006 | 08:08 PM
wheelzy's Avatar
Tires are same size. Never thought about the kmh instead of mph. Is there a way to switch back and forth between them? I could of swore it was mph. I will check it out . thanks wheelzy
Old Sep 5, 2006 | 08:45 PM
OGGYDOGGY's Avatar
In an artical in dirtwheels a while back they said the Grizz tested in 04 was around 8 mph off reading too high with the stock tires , I put 27' tires on and with gps got 61 mph and on speedo got 61. the bigger tires gave it a true reading. It really frosted me that the manufacturer cant make the speedos accurate.Now I have 26'tires on to be a little easier on the stock clutches.
RedRancher
Oct 15, 2020 01:45 PM
greg74
Sep 10, 2019 03:03 PM
Bratman2
Jul 25, 2015 07:16 PM
hondarider1234
Jul 21, 2015 11:53 PM
toonces
Jul 11, 2015 12:01 PM
