350 to 400 cylinder swap
Old Sep 5, 2006 | 09:28 PM
conan2005's Avatar
Default 350 to 400 cylinder swap
I got a 91 polaris trailboss with a fried cylinder and piston ( actually the celinder is missing due to an unfinished project) . I also have a 400 polaris motor that is bad except for the cylinder. I was wondering if the 400cylinder will work on the 350. The bolt pattern is hte same and it looks like all the other plunbing lines up also. All except the sleeve in the cylinder touches the block a little bit, I think could be fixed. Also not sure about the stroke? Any help would be greatly appreciated.
Old Sep 8, 2006 | 09:57 AM
scramblered's Avatar
no problemo,there only one thing different separatly is the case and cylinder,,all base case are the same through the years,,only the jugs design and porting through them is change from scrambler to sport to trail blazer then finally.you'll have better power with that jug if it is a '96 or newer model.
Old Sep 8, 2006 | 10:45 AM
RickRitter's Avatar
You must use the 400 cases with the 400 cylinder . The 400 cylinder will not fit the 350 cases .
Old Sep 8, 2006 | 06:26 PM
conan2005's Avatar
so which is it, yes or no. I don't really want to shell out money for a new cylinder.
Old Sep 8, 2006 | 07:43 PM
x_scrambler3's Avatar
It is no I would trust ricks ritter
Old Sep 8, 2006 | 11:33 PM
RickRitter's Avatar
A 400 cylinder will not bolt on to a 350 lower end .
Old Sep 9, 2006 | 07:43 PM
conan2005,i have an 020 jug that is still pretty usable if you're looking to get one at lower price.
Old Sep 10, 2006 | 01:58 AM
conan2005's Avatar
Sure if its the whole cylinder then I would be interested. shoot me a price
Old Sep 11, 2006 | 10:57 AM
shoot me a message and it can be for you,,,
Old Sep 11, 2006 | 08:30 PM
conan2005's Avatar
I found one for fifty dollars so if u can beat that i might be interested
