blaster mods?
Old Sep 7, 2006 | 09:23 PM
blasterboy68's Avatar
Default blaster mods?
is there any thing i can do to my blaster that will make my quad have more power (in mind that i love mud and playing in the woods/logging trails without doing much to the heads or jets?) i got a k&N filter getting a FMF sst pipe with a powercore 2 silencer.
Old Sep 8, 2006 | 03:08 AM
fastestkidaround's Avatar
port and polish. that would be good. get a 28mm carb and u will have a lot of power over stock imho. that would be about all i would do for trails and mud. then get some good tires, bars, and stuff like that. u dont need much more motor in the woods. mine does great on the track since i got it ported and shaved but i also does well in the woods and mud with my buds.
Old Sep 8, 2006 | 10:40 PM
Boomer2's Avatar
Jets don't add power. If you are adding a pipe and air filter, you are going to have to mess with the jets. You can advance timing, by adding a Vito's degree key($20), or making stator adjustable Adjustable Stator. You can mill the head for increased compression($30). Add a aftermarket reed cage($150). Or aftermarket reed petals ($30). Reed Spacer ($30). The reed cages, reeds, reed spacer don't add alot of power, but add throttle response, which is good for the woods. Advancing timing and increasing compression add low end torque.
Ahtatu
Sep 28, 2015 12:14 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1ArmBandit
Sep 8, 2015 08:59 PM
