Flywheel
Old Sep 10, 2006 | 12:28 AM
MrMeaner's Avatar
Default Flywheel
Anyone ever had the flywheel off and 05. Mine wont come off with the ouller and Im stumped. The one on my 01 came right off easy
Old Sep 10, 2006 | 06:40 PM
choosetolose04's Avatar
Default Flywheel
Wish I could help ya Meaner. But I dont have a clue. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Sep 11, 2006 | 09:41 PM
MrMeaner's Avatar
Default Flywheel
hmmmmmmmmmmmmmmmm
Old Sep 11, 2006 | 10:07 PM
OMR's Avatar
OMR
Is Oldmanracing! Also the inventor on the DS650 carb Mod!
Default Flywheel
The center hub needs alittle heat - loctite from factory sometimes won't let go.
Heat the hub with a torch, not much, install puller, draw tight, side hit flywheel with brass, tighten puller, side hit and usually it will pop.
Be sure to use pressure lube or good grease on threads and end of puller.
OMR
Old Sep 16, 2006 | 01:35 AM
MrMeaner's Avatar
Default Flywheel
Still wont come off
Old Sep 16, 2006 | 11:23 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Default Flywheel
I do the same thing OMR said but when I have it as tight as possible I hit the center of the puller bolt with a hammer and send a shock wave thrue it and it usually comes rite off.
Old Sep 17, 2006 | 12:24 AM
MrMeaner's Avatar
Default Flywheel
Ill try that tomorrow
Old Sep 17, 2006 | 12:41 AM
ds650ctracing's Avatar
Default Flywheel
Could this hurt the crankshaft in anyway ? like by hitting the flywheel to hard.
Old Sep 18, 2006 | 10:12 AM
Tpsycho's Avatar
Default Flywheel
Yes it could just use your better judgement and do not use a BFH [img]i/expressions/face-icon-small-smile.gif[/img]
Old Sep 18, 2006 | 12:33 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Default Flywheel
I had the same problem on my craptor. Flywheel would not come off for the life of me. broke a cheap puller. then aquired a nice matco puller. it took around 300ft/lbs before it popped. wich mushroomed the crank. had to grind down the shaft and recut the threads at the end. Royal pain. I did not use heat. Next time. Heat will be used [img]i/expressions/face-icon-small-wink.gif[/img]
Good luck
