700 electrical problem
Old Sep 10, 2006 | 05:47 PM
TheWayOut's Avatar
Default 700 electrical problem
This problem is on a 2002 700twin. With the engine running or stopped all electrical functions will shut off then come back on. Just like a light switch, any suggestions to my problem. It is completly speratic. Thanks in advance.
Old Sep 10, 2006 | 07:41 PM
SAshton's Avatar
could be a loose ground. check any ground wires mounted to frame 1st.
Old Sep 11, 2006 | 01:43 PM
TheWayOut's Avatar
Could this possibly be a circuit breaker, if so where is it located?
Old Sep 11, 2006 | 06:32 PM
Saskie's Avatar
I had the same problem for a long time on my 02 700. I found the 20 amp circuit breaker, located under the front panel below the headlight pod, was full of corrosion. The circuit breaker is encased in a black heat shrink bad. You have to cut the bag open to access the circuit breaker. I bought a new circuit breaker and installed it. You can find them at any automotive repair shop. You have to seal it up after you connect the wires again. I recommend some di-electric grease on the ring terminals as well.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
