Trying to figure out parts I need off of microfiche...
Old Sep 11, 2006 | 12:49 PM
JMann2380's Avatar
Default Trying to figure out parts I need off of microfiche...
The first part I am trying to find is the pin and spring that attaches the rear brake lever to the rear master cylinder. Its attached to the frame but just pivots on there and you can spin it around till it hits the footpeg. On the fiche it kinda looks like it maybe 86???:
The second thing I am trying to do is rebuild the front brake master cylinder if its possible. I have two master cylinders but I think they have been sitting along time and the seals and such are work out and the piston is just pushing through the fluid. Trying to bleed the brakes it build slight pressure but never holds. The pistons and lines seem fine, no leaks or anything. Can anyone tell me what part and # to order on this diagram to rebuild the cylinder, here is a link to the list and the microfiche:
PARTS LIST
MICROFICHE
Thanks,
Josh
Old Sep 11, 2006 | 09:19 PM
cloftis's Avatar
#67 is your lucky spring number!! no answer on front brakes someone else help?
Old Sep 20, 2006 | 12:04 AM
95Wolverine's Avatar
Unless the master cylinders you have were sitting bone dry for a very long time, it's unlikely that they are bad. The brake fluid has a lubricant built into it that sticks around to keep the rubber in good shape.
Have you tried doing an extremely patient brake bleeding process? If not, do that, if so, I'd say part #21 (piston kit) would get you the replacement parts.
TheHood
Aug 8, 2015 05:49 PM
Bulgin88
Jul 30, 2015 05:20 PM
toonces
Jul 28, 2015 01:58 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
