500 head milling
Old Sep 11, 2006 | 09:07 PM
drlang's Avatar
Default 500 head milling
On a sportsman 500 non ho. But will be putting in an ho cam. How much can be milled off the head before you can't run pump gas? Or run into valve clearance issues. Will be using a wiseco standard compression piston. Basic reason for the mill is a cleanup since it needs the cam replaced, will be boring also. 5000 miles it's time for a bit of work.
Old Sep 11, 2006 | 11:27 PM
squeege's Avatar
I think compression wise you need to stay under 160? not sure....
Old Sep 12, 2006 | 12:59 AM
sheepdogMSP8117's Avatar
Compression ratio is what dictates octane requirements from what I understand. As far as how much you can shave from the head, I couldn't tell you.
Old Sep 12, 2006 | 01:03 AM
RickRitter's Avatar
Don't mill that head for compression !
Problem 1 --> Cam timing gets thrown off .
Problem 2 --> Valves can tangle with piston .
Buy a hi compression wiseco piston .
Old Sep 13, 2006 | 02:09 AM
drlang's Avatar
Thanks guys. Now that we've got that answered. If this thing needs resurfacing, what would be acceptable there? A couple of thousandths for a cleanup? The owner said that it has gotten hot several times and would like to make sure the surface is true.
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
