Aaen vs. gutted duals
Old Sep 12, 2006 | 07:23 AM
jordo's Avatar
Default Aaen vs. gutted duals
Anyone run gutted stock pipes? My Aaen is not doing very good and i was thinking about gutting the stock pipes. Also a sound clip would be nice.
Old Sep 12, 2006 | 08:12 AM
spyder6's Avatar
donno how you'd manage to gut the stock pipes without cutting them open. they're completely sealed.
Old Sep 12, 2006 | 02:02 PM
xler8ion's Avatar
I have been looking at that aaen pipe for some time and been waiting for comments from people who have run them. When you say your aaen is not doing good what do you mean? The stock pipes I have seen on here gutted or modified have run the exit straight out the rear with a turndown and some have done it to both of the duals and other just kept the right side one and plugged the crossover. I have never seen a dyno or timing tests to see the results. Others may have but I bet the gains are minimal.
Old Sep 12, 2006 | 05:03 PM
jordo's Avatar
I thought the Aaen was good until it started falling apart. The inside rattles and it used to leak. You aren't going to gain much with any pipe on an 800.
Old Sep 12, 2006 | 05:24 PM
SCRAMIN's Avatar
i have had great luck with aaen call ask them they might replace it ? what are you out ? if you cut out you stock it will make it louder and gain a little power but with out proper back pressure will burn exhaust valves and decrese cylinder pressure and adventually loose power!!!!! and have to rebuild head. had to on old king quad exhaust went bad left it that way took less than a year to burn up valve was never the same just my opinion
Old Sep 12, 2006 | 08:03 PM
xler8ion's Avatar
True enough jordo on the gains but I guess it is all relative. Aaen's dyno results claim @3hp and 5 lb/ft with flatter curves on both. How did it feel to you? I agree with scramin if you liked it ask for a replacement-can't be that old on an 05 like mine
greg74
Sep 10, 2019 03:03 PM
Sep 30, 2015 01:37 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
mitchxc700
Aug 10, 2015 09:26 PM
