How to bleed rear brakes?????
Old Sep 12, 2006 | 11:57 PM
itsjustagreat1's Avatar
Default How to bleed rear brakes?????
I have a 1997 trailblazer 250 and am trying to figure out how to make the friggin rear brake pedal to work. How do you bleed it? when I use the front lever the rears brake, but if I step on the pedal they don't. When I squeeze the hand lever and then step on the foot pedal, I feel more pressure on the hand lever, so I figure there must be air, but how do you correct it to make it work?? HELP!
Old Sep 13, 2006 | 10:26 AM
rundrave's Avatar
on the rear caliper there are 2nuts with rubber caps on them. take the rubber cap off of the one break line that is for the foot pedal. you should see a small nut with a little hole on top of it. take a small piece of clear hose say 4" long that has a diameter that fits right over this little hole. You want the hose to be tight around this little hole, but not so tight that you cant get your wrench around the nut right below it.
Fill this hose with about 2" inches of break fluid and bend the end of the pipe so it is bending towards the ground.
Now go to your foot pedal and remove the cap of the brake master cylinder, use a small funnel if needed or just pour it in as you go. The key here is to NOT let any air into here.
Losen the bolt on the caliper with the hose on it very slowly and as your doing that tap the brake pedal with your hand. Do not completely press the pedal down or you will push out to much fluid. Just tap it over and over and you will start to see bubbles in the clear hose. Keep tapping until the bubbles stop but you will also need to keep adding fluid up front to keep the air from coming in.
The reason I say bend the clear hose down is by doing so, gravity almost does the work for you. It may take quite of few taps on the pedal, but once the bubbles stop, tighten the bolt on the caliper, add desired fluid, put the cap on and you should be good to go.
Its almost a 2 man process but you should only have to do it once. I did it on my scrambler and havent had a problem since. It may take you a couple times, but you will figure it out. good luck
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Aug 14, 2015 05:59 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
Sandman2.0
Jul 21, 2015 09:03 AM
