02 grizz noise in belt area
Old Sep 13, 2006 | 12:40 PM
GRIZZ02's Avatar
Default 02 grizz noise in belt area
I have a 02 grizzley and it started making a whining noize in the belt housing when I slow almost to a stop.I replaced the belt but that didn't fix the problem, the old belt I replaced look as good as the new one , since I had it apart I replaced the belt because the old one had 3200 miles on it. Has anyone else had this problem ?
Old Sep 13, 2006 | 04:48 PM
hondabuster's Avatar
did you also regrease the weights when you replaced the belt?
Old Sep 13, 2006 | 05:12 PM
GRIZZ02's Avatar
No, did not no how to grease them but I got some good info from grizzhopper.com so I'm going to grease them tonight.
Old Sep 18, 2006 | 04:53 PM
GRIZZ02's Avatar
I cleaned everything in the belt housing and regreased the weights per grizzhopper.com and I still have the same noise, sounds like the noise is coming from the secondary sheave but I'm not sure and only when the machine is cold,after it warms the noise is gone. HELP!
Old Sep 18, 2006 | 05:09 PM
Did you disassemble the secondary sheave? There are followers for the cam profile which could be siezed, or unlubricated or rusted. Also theres a spring which could be broke.
Youll probably need to take it apart and look it over.
Old Sep 19, 2006 | 09:45 AM
GRIZZ02's Avatar
Thanks for all the help hondabuster,do I lubricate the followers with the same grizzly grease or something different and is their any special thing I have to do to remove the secondary sheave or any special tools needed. Thanks!
Old Sep 19, 2006 | 08:20 PM
You dont have to buy a special tool, but youll need to come up with a way to compress the spring and hld it while tightening the nut.
I sent a PM.
flyin-lowe
Dec 1, 2017 03:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
jankerstien
Sep 21, 2015 03:09 AM
firsttimerider
Sep 20, 2015 09:07 PM
toonces
Sep 5, 2015 01:14 PM
