It didnt cut off when i turned the switch?
Old Sep 13, 2006 | 08:15 PM
warriorman16's Avatar
Default It didnt cut off when i turned the switch?
ok here it is...i put in a new batterie today and turned the switch on to see if it worked and when i went to cut the switch off the motor didnt cut off!!! so i had to hit the kill switch. does anyone know what the problem might be?
Old Sep 13, 2006 | 08:35 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
cut the swithc off as in the key?? or is there a teather kill switch??
Old Sep 13, 2006 | 09:17 PM
yea the key... hahaha i even took the key out and it was still running. It might be something in the ignition.
Old Sep 13, 2006 | 09:45 PM
HMFIC's Avatar
There is a wire that goes to the cdi box to kill the engine. I can't remeber if it is black with a white stripe or white with a black stripe. It is one of the two. If you look around the battery and at the wires around it you have probably disconnected it. If it is not hooked up you kill switches won't ground out the ignition and kill the motor because even though you cut them to the off position the cdi doesn't know it.
Old Sep 14, 2006 | 12:31 AM
recon99's Avatar
Does it do the same thing every time, or was it just a one time deal? If it does it every time, here's where i'd start my troubleshooting: First, i'd take off the headlights and remove the 4 screws that hold the hood down. Then I'd fire it up, and if the key doesn't turn it off, unplug the key switch from the wiring harness. If it shuts off, you need to replace your key switch. If it keeps on running, your problem is elsewhere.
skinnyr6
Aug 25, 2023 02:18 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
cornermike
Jul 8, 2015 11:44 PM
ranvette
Jul 4, 2015 06:13 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
