2005 ds650 oil censor ?
Does this happen to any of you guys?It just happened luckly it was under warrenty.My red dash light kept coming on.Saying it was hot but i just started it.My ds is brand new and i hope this doesnt happen all the time.Does this happen to alot of you guys?I love my ds and i hope this isnt a frequent accurance or ill get rid of her. Any feedback is helpful Thanks.
I always look in the oil tank with a flashlight while the motor is running and watch for flow. You should see the oil moving by at a pretty good clip. If you have blockage or pump failure anywhere in the motor, it will slow or stop the oil movement at the tank.
When everything is working properly, get used to the speed the oil moves at..........If it slows down, you need to start checking things out[img]i/expressions/face-icon-small-wink.gif[/img]
check the screen in the bottom of your oil tank also. that will slow the circulation down also.
I have the same problem as well. I havent located it let. Another local DS rider also has the same problem. He said that the senors like to act-up. I took the DS into the local dealership this spring and all they could find was the fan wasnt workin. BRP should look into this problem for the future.
I had this problem twice, both times were related to getting it wet going through semi-deep water, second time I had the dealer seal it in with silicone, there is a boot available for it now. I'm willing to bet this is your problem.
