Several Questions
Old Sep 18, 2006 | 11:08 AM
superintendent's Avatar
Default Several Questions
I just purchased a 2003 sportsman 500 HO with 700 miles. There seems to be a slight ticking that sounds like a lifter or valve tappet. Is this common? Should the valve clearance be adjusted at certain increments?
Thanks for your help!
Old Sep 18, 2006 | 11:13 AM
motoman67's Avatar
is it making this noise at idle ? sounds like your hearing the oil pump they make aticking noise at idle and yes these is normal
Old Sep 18, 2006 | 11:23 AM
When I first start the engine it is very quiet then about 30 seconds later I begin to hear this noise. If this is normal I will not worry about it, the engine starts up and runs real strong so there is not a performance issue. I just tend to be over zealous about my toys and since I am just re-entering this world of ATVs I am just that much more cautious.
Thanks for your help..
Old Sep 18, 2006 | 11:39 AM
NBsportsman's Avatar
It's tha nature of the Fuji engines to tick. I had the valves adjusted on my 500 once at the first service and now it has close to 7000miles with no problems...
Old Sep 18, 2006 | 11:50 AM
Thanks, I appreciate the feedback!
Old Sep 18, 2006 | 03:07 PM
BassBlaster's Avatar
My Scrambler makes that noise at idle also. It's nothing to worry about.
Old Sep 18, 2006 | 03:11 PM
Thanks for your input, I appreciate your advice...
Thanks, John
Old Sep 18, 2006 | 03:17 PM
Nb sportsman, tell me about the front spacers you have on your ATV. My sportsman 500 came with a County Plow and the front end seems to sag quite a bit with the plow in the up position. WOuld a simple fix be to add a spacer?
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
