any thoughts on hoping up a 2003 Raptor
Old Sep 20, 2006 | 07:22 AM
ducman's Avatar
Default any thoughts on hoping up a 2003 Raptor
I have a rs3 full system k&n jetted and I am down 1 tooth in the front.
NO I want it fast
Any thoughts and speds on maybe where I am and where I could be. Thanks Ryan
Old Sep 20, 2006 | 07:58 AM
paintballbanshee's Avatar
Open up that air box with like 10-12 air vents and plop in a k&n air filter setup.. that should give some hp. Then you can go with hotcam or w.e they say is a good cam. You dont have the stock tires do you? If you do get them off and replace them with razor 2's or whatever you can find that is good.
Old Sep 20, 2006 | 11:58 AM
DriverDoyle's Avatar
If you want real power out of that rappy..Your going to have to spend some money...
1. CP lightend 12.1 piston..( IMO But can use any pistion you want)
2. New rod (for safty)
3. Cam (anything but stock)
4. Mild port job ( i would use craycraft or kenz)
5. Carbs (I would go with FCRs)
All the above..Or just a few things..Will help alot...You can get a 686 kit with 12.1 cheep just look on ebay..Or if you want it built right..send it to bob craycraft or kenz cycle..and send them about $2000.00 and you will have a STRONG MOTOR..
Old Sep 20, 2006 | 03:08 PM
ducman's Avatar
I was thinking about doing the 686 stroker kit and a stage 3 cam. but I am not sure about what I will gain as far as hp and tourque vs the money it will cost. What are some thoughts on it?
ducman's Avatar
this kit makes it a 719cc
Old Sep 25, 2006 | 11:54 PM
grobus15's Avatar
Hi, I have a 03 raptor. It has a trinity 727 big bore kit. It is a 105mm 11:1 piston, ported head, stage 3 cam, ct racing pipe, jet kit, k&n fiter with vents in the air box. my gearing is one down in front. my bike ******* in third gear with out trying, and it hits 90 in 4th gear. not sure about 5th, over 100.
Old Sep 26, 2006 | 12:12 AM
ducman's Avatar
what is your guess as far as power and do you know what stock is? Thanks Ryan
Old Sep 26, 2006 | 12:29 AM
bad350twin's Avatar
Shoot me a pm and i can help ya out!
Old Sep 26, 2006 | 01:55 AM
ducman's Avatar
This will sound stupid but how do I PM?
Old Sep 26, 2006 | 05:42 PM
busman's Avatar
private message that be a PM
Nondem
Feb 22, 2020 12:20 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
