raptor cut out problem!
Old Sep 21, 2006 | 06:47 PM
grobus15's Avatar
Default raptor cut out problem!
I have with my 03 raptor 660, it will start and idle fine, but when I get to the midrange it starts to cut out like a rev limiter. If I pull in the clutch slightly it will rev up a little high, but stills does it. I have cleaned the curbs, adjusted the valves, and replaced the coil and the spark plug. Replaced the switch on clutch lever and the parking brake. I haven’t put anything new on it to have to change the jets. Hear is what I have on it. I have a 727 big bore kit on it with 11:1 compression, ct piping and jets, k&n air filter with vents in the air box, works shocks, +2 a-arms , 2+2 rear axle. Hole shots front and rear. It rips. I hope that someone can tell me what to do about it. thanks for your time
Old Sep 21, 2006 | 09:19 PM
OneFlyCowboy's Avatar
Monkey Rider
Afro-Engineer
FREE AND NOW are the best
Mine was doin the same thing.. and it was just a dirty airfilter & outerwear. [img]i/expressions/face-icon-small-shocked.gif[/img]
Often causes are things such as float levels? or you could have a short in your wire harness or bad CDI. thats about all i can think that would cuz those symptoms
Old Sep 26, 2006 | 12:07 AM
grobus15's Avatar
thanks, i will have too try these things out.
Old Sep 26, 2006 | 02:01 AM
aqharoper's Avatar
I am by no means mechanically inclined. I have 2 raptors and my wifes had the same problem. I cleaned the carbs and found some debris. It ran for a day then repeated the problem. I did this process 3 times. What I finally discovered was one of the fuel hoses were breaking down and the debris I found was from the fuel line. I replaced all of them and it hasn't been a problem.
Old Sep 26, 2006 | 11:39 PM
grobus15's Avatar
thanks dude, but I have already switched out the fuel line and the petcock fiter screens. but thanks for your input.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
