Sportsman 500 clutch problems
Old Sep 22, 2006 | 09:40 PM
extreme4x4's Avatar
Default Sportsman 500 clutch problems
This is beyond me. About 10% of the time from decelerating from wot, it seems as if the ebs is not engagin and im just freewheeling. It coasts, meanwhile i can here the belt hitting the cover. Then when you go to accelarate again, it bogs down hard, to the point you have to put it in low to get going again. After accelerating in low, stoping and switching back into high it is fine. Belt looks fine to me, npo cuts, tears, burn marks etc.
Anyone have any ideas before i send it out?
Old Sep 22, 2006 | 09:45 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
pull your cover off and take a look. could be a few things going on. sounds like the spring let go in the secondary. maybe some problems w/ the ebs bushing. seeing is beleaving.
Old Sep 22, 2006 | 09:50 PM
extreme4x4's Avatar
Stendori, I have the cover off. Is there anyway i can check the secondary spring without pulling the secondary off? Can you explain to me how the ebs bushing works?
thanks alot
Old Sep 22, 2006 | 09:54 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
take off your belt and take a look at the primary (engine clutch) in the middle is a groved bushing that is the ebs that rides in the groves on the inside on belt. make the belt is still in good shape not damaged or burned up. as far as the secondary, try to pull the sheeves away from eack other like one clock wise and the other counter clock wise there should be a spring like action that closes them back together.
Old Sep 22, 2006 | 10:36 PM
2manytoys's Avatar
Either sounds lik the secondary spring or the ramp buttons. The buttons wear and they start to eat into the ramp and stick on downshift.
Old Sep 22, 2006 | 10:42 PM
extreme4x4's Avatar
I know this is dumb. But how do u get the belt off. I am used to polaris sleds that u thread in the special screw to spread the secondary. But there isnt one on these??? And im not stong enouygh to turn the sheeves opposite directions to spread it with the belt on there.
Old Sep 22, 2006 | 10:46 PM
extreme4x4's Avatar
Is the correct way really to pull/stretch it over the outside of the secondary?
Old Sep 22, 2006 | 11:20 PM
2manytoys's Avatar
You can roll the belt off of the secondary. Just pull the belt up between the primary and secondary then roll the clutch twards the back and roll the belt off the secondary.
Old Sep 23, 2006 | 12:13 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
if you cant pull the sheeves apart chances are the spring is not broke so more likely it could be the buttons are worn out like 2 many said. you can put the bike in neutral and roll off the belt by rolling it backwards and pulling it off at the same time. either way it sounds like your secondary clutch should come off and be checked.
Old Sep 23, 2006 | 04:10 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hey extreme4x4, how did youy make out w/ the clutches? what did you find wrong with them. let us know.
