oil change for rancher es
Old Sep 23, 2006 | 08:01 AM
sledge172's Avatar
Default oil change for rancher es
what is the best oil to use when changeing oil in rancher es? auto oil ok to use if it is should i use synthetic or regular? also whats the best weight oil. ty for any info sledge
Old Sep 23, 2006 | 06:23 PM
toml85's Avatar
Use the search feature on here and you will find thousands of answers on oil!!! It all depends on what you want to run in it but at least make sure it is a motorcycle/ATV type oil. Supposedly you can't run regular automotive oil in them because of the fact that it circulates throught the transmission as well as the engine. Just to be on the safe side I always just spend the $3 a quart and buy the Honda oil that is recommended in the owner's manual (I think it is the GN-4 10W-40). That way no one can say I used the wrong oil!!!
Old Sep 23, 2006 | 08:17 PM
Gruzzy's Avatar
Most automotive oil has moly in it which is bad for your clutch. The best oil is labeled JASO MA, which has no additives which could cause a clutch to slip.
Oil is probably the biggest debate on the board. I use a synthetic oil specific for 4 strokes and JASO MA certified. Why, I want my engine to last a long time and being air cooled, the synthetic lowers engine temps a little. Important in 100 degree summers. Synthetic oil clings to engine parts better resulting in less wear over time. Just my opinion.
Old Sep 24, 2006 | 10:19 AM
buckweet1234's Avatar
i use shell-rottella syn, 5-40 no moly in it, runs cooler i believe, and i've used the stuff in my goldwings for years, great stuff.
and its cheap @ china-mart.
weet
Old Sep 24, 2006 | 10:36 AM
sledge172's Avatar
thanks for the replys guys, i think i will use the manufactures recomindation after reading the owners manul. plan on keeping quad till the day it blows up witch will hopefully be quite a few yrs. ty for info sledge
Old Sep 24, 2006 | 02:12 PM
ddrumman2004's Avatar
I use synthetic oil in all my atv's. If you want to pay the Honda dealer what they want for the Honda oil then go ahead. But for the money, you can't beat Shell Rotella synthetic that's avaialble almost anywhere.
I myself spend the money for Amsoil 0W-40 that's rated JASO-MA for atv's and snowmobiles. No more than we ride, I can get by with once a year oil changes.
Like I have posted elsewhere, the synthetic oil stopped the Yamaha Bruin from smoking on start-up.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
rgjackson
Sep 17, 2015 11:21 AM
bigbear350quad
Sep 11, 2015 12:40 PM
Jason Campbell
Sep 7, 2015 02:25 PM
Elkaholic
Sep 6, 2015 02:44 PM
