Blaster FMF pipe
Old Sep 27, 2006 | 12:00 AM
LeeEOD's Avatar
Default Blaster FMF pipe
I just got an FMF Fatty and turbine core 2 for my 06 blaster and it comes with a head piece that bolts to the jug and the pipe slips over it. But the pipe has a spring and loop but there is no plase to put the other end of the spring. I got all but the spring on and it leaks just a little right at that junction where the pipe slips over the head piece. where does the spring go or how can i fix the leak.
Old Sep 28, 2006 | 10:51 AM
04BlasterRider's Avatar
there should be a little loop on the pipe itself, and then a loop on the 2 hole mounting bracket that mounts on the motor , the spring goes through the one on the pipe and hooks on to the bracket. hope u understand this
Old Sep 28, 2006 | 04:19 PM
MDS2106's Avatar
I drilled a small hole in the fender brace that runs across the frame from one fender to the other and hooked the spring in there, it worked great.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
nastyblaster100
Sep 13, 2015 01:19 PM
