Removed oil injector Alpha Sport 90
Old Oct 2, 2006 | 01:39 AM
JBL's Avatar
JBL
Default Removed oil injector Alpha Sport 90
Had to remove due to pipe melting oil reservor and new throttle cable. Now I have the old throttle cable that controlled the oil and the oil lines hanging without a clue how to completly remove them. There is an oil warning light that now stays on since the removal obviously since its not reading oil, but Im concerned I may be doing some damage. Did the 2 stroke injector oil keep anything else lubricated? Are there any specific tweaks I need to do when I remove the cable/hoses? I mix my gas 32 to 1
Thanks for your tips!
Old Oct 2, 2006 | 06:55 PM
MINIQUAD97's Avatar
the only thing the oil injector done was mixing oil with the gas by removing it you have to mix your own gas now but to remove the cable take the cover off the right side of the engine and you will see that the cable is easy to unhook as far as the light it should go out after you unplug the wire most of the time you have to put a sigle cable on and the throtle will be easier to operate
Old Oct 3, 2006 | 02:45 PM
JBL's Avatar
JBL
Thanks I'll take care of it today!
Old Oct 5, 2006 | 12:06 AM
BIGWORM3699's Avatar
You can leave the oiler in place it wont harm anything. Make sure you block of the port on the carb so you dont lean out the bike.
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Jason Richards
Sep 4, 2015 06:17 PM
Sep 1, 2015 11:59 PM
Cantbuytime
Aug 16, 2015 09:13 PM
