Removed lift and tightened wheel hub. Now axle clicks.
09 Mudpro 700. Had a 3 inch lift so I went to remove it and when I jacked it up the left rear wheel was flopping around. Removed the wheel and the hub nut was loose. So I tightened it by hand. Not spec. Spec is 200 ft lbs.
Then I removed the 3 inch lift. Now every time I turn the left rear cv axle is clicking and popping.
What did I do wrong here?
