Repairing Plastic
Old Dec 6, 2000 | 10:12 AM
cheesehead's Avatar
Hi Guys. I have a Fourtrax with all of the usual cracks and holes in the plastic. Whats the best way, short of replacement, to repair this? My plan was to back up the cracks and holes with flexible plastic and pop rivet the patches in place. Then, since this machine is used mostly for hunting, I thought I would cover all the plastic with one of the cammoflage tape kits that is available. Has anyone used one of these kits? Do you think this repair will work? Any suggestions are really appreciated! Thanks, Tom (Cheesehead)
Old Dec 6, 2000 | 01:13 PM
plp2's Avatar
tie wraps instead of rivets
Old Dec 6, 2000 | 02:08 PM
retro's Avatar
You can try melting the plastic together with a soldering gun or drill small holes in the plastic and use zip ties every 1/2" or so along the crack.
ERIC
Old Dec 6, 2000 | 03:36 PM
dixie4trax's Avatar
You can get an ATV fender repair kit..."plastic welding kit" from
http://www.urethanesupply.com/atv2.htm
They designed their own heat gun with a slot to feed their plastic welding rods through. I've used it and I'm sastified with my repair. It leaves a scar but the repair is strong.
Old Dec 8, 2000 | 08:18 PM
SITnSPIN's Avatar
I got a huge crack in the front plastic when the shovel fell off the front rack and i ran it over. i am going to try to get it plastic welded. by the way, the shovel broke.
Old Dec 8, 2000 | 08:29 PM
norcalatver's Avatar
I have also seen the plastic welder used, but the guy welded the cracks from the under side only and you could barely tell that the fenders were ever broken.
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
firsttimerider
Sep 20, 2015 09:07 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
