01 Warrior has no spark
Old Oct 7, 2006 | 07:08 PM
Warrior718's Avatar
Default 01 Warrior has no spark
I bought a 01 warrior that was not running at the time and got a great deal.It cranks but has no spark.Tested the source coil and pulse coil and pulse coil was bad. Replaced pulse coil and rechecked and reading on pulse coil and source coil is now proper.Replaced battery with new.I ohm tested ignition coil only reads 1 ohm. Does anybody have proper reading for ignition coil?Does any body know proper procedure for testing module without replacing. Do not have service manual available to me this at this time. Any help would be appreciated.
Old Oct 8, 2006 | 11:42 PM
Warrior718's Avatar
I checked ohm reading on a friends warrior ignition coil and it was close. When I crank engine with test light in posative to ignition coil it flashes as it cranks and on mine it does not. I would assume the cdi box is bad.Anybody have a way to verify this. His warrior was a 2004 or I would have swapped it to test it.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
