Off Topic Any Ford Mechanics out there
Old Oct 9, 2006 | 07:19 PM
atvaddict01's Avatar
Default Off Topic Any Ford Mechanics out there
I got a diagnostic code on our windstar that Autozone cant tell me what it means.
It was P 2004.It also said something about the intake manifold.
If anyone knows what it means could you tell me before i take it to the dealer.
Thanks alot
Greg
Old Oct 9, 2006 | 08:55 PM
DuneMe's Avatar
No idea but, if intake manifold - check your Mass Air Flow sensor. Maybe it is dirty. What's your air filter look like? Check your air intake to make sure it is still connected and no leaks on your air intake.
If you find something, it will probably take about 6 starts before it will clear.
Otherwise. . . head on down to the Stealer. [img]i/expressions/face-icon-small-sad.gif[/img]
Old Oct 9, 2006 | 09:18 PM
Air filters are new.What is the mass air flow sensor.And where is it.
Old Oct 9, 2006 | 09:20 PM
SPORTSMAN70003's Avatar
We have an OBD II code reader and I can't find that that code you gave. Are you sure thats the code they gave you? Most codes will start with a P0 or P1.
Old Oct 9, 2006 | 10:21 PM
Yeh thats the code.Their computer couldnt find a match either.
Old Oct 9, 2006 | 10:34 PM
Sorry I couldn't help. I check peoples codes everyday and have never seen a code like that. Hope you get if fixed soon.
Old Oct 9, 2006 | 10:47 PM
bombrider04's Avatar
It is the intake manifold runner central stuck open bank 1a)
Old Oct 10, 2006 | 12:13 AM
DuneMe's Avatar
Mass Air Flow Sensor is on the intake tube after the filter and before the intake manifold. It has wires going to it.
I've heard of guys having issues with them (especially if you have a K&N type filter (oils get on them I guess).
Delicate so, when you pull it be gentile. Disconnect the wires and then pull the sensor. From what I hear you can spray carb cleaner on it to clean it up a bit.
This doesn't sound like your issue. Sounds like you've got an issue in you intake manifold or your throttle body.
Old Oct 10, 2006 | 06:12 AM
I did a little research and what i found was a shutter valve is stuck
open.Looks like my ford has some mazda parts on it.
Way beyond my skills.Looks like the stealer is getting a visit
from me today.Thanks for the help everyone.
2quiker
Mar 22, 2022 08:36 PM
Customer Service #1
May 15, 2020 08:46 AM
flyin-lowe
Dec 1, 2017 03:18 AM
jdunne01
Oct 4, 2015 10:29 AM
Sassinm1
Sep 30, 2015 04:23 AM
