Main frame tube wall thickness?
Old Oct 9, 2006 | 11:51 PM
Turtler's Avatar
Default Main frame tube wall thickness?
I have an 02 660 Raptor and had the subframe crack in a couple places as well as the two lower mounting brackets coming off of the main frame that secures the subframe to the main frame. The mounting points for the exhaust got ripped off and I lost my silencer in the process.
Would any of you know the wall thickness of the main frame, down tube that attaches the brackets for the lower mounting points of the subframe? That will help me dial in the welder settings.
Old Oct 11, 2006 | 12:09 AM
Turtler's Avatar
Help me out here guys. I called Yamaha's "customer service" number and said the wall thickness of the main frame tube and material is unpublished information and wouldn't give me the info. There is a tech line but wouldn't give me the number and told me to call the dealership. Better yet, he told me to just buy a new main frame.
I am pissed as hell with this kind of response. Hopefully one of you have found out this information.
Old Oct 11, 2006 | 12:42 AM
UBETRUN's Avatar
I've welded on them but I don't know the thickness. It's thin wall tubing, you don't need a lot of heat. Best way to figure it out is to start with less heat and crank it up if you don't get enough penetration.
Old Oct 11, 2006 | 03:03 AM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
I have a frame I've had to tig some cracks on.........It's thin wall tubing make no mistake about that....
Take Ubet's suggestion and start at a low heat range and see how your bead lays down.......Good Luck [img]i/expressions/face-icon-small-smile.gif[/img]
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
