Now I'm Screwed
Old Oct 14, 2006 | 02:14 AM
Zen's Avatar
Zen
Default Now I'm Screwed
I turned off one of the bolts for the clutch cover. Need some help here......................
Old Oct 14, 2006 | 02:31 AM
400fnSport's Avatar
did u round it or break it? If you rounded it, it may be possible to cut a slit in it and use a flat head screw driver to get it out.
Old Oct 14, 2006 | 02:37 AM
Zen's Avatar
Zen
I friggin broke it off
Old Oct 14, 2006 | 08:49 AM
mizer's Avatar
drill and easy out be careful not to get off center
Old Oct 14, 2006 | 09:40 AM
FASTFATBOY's Avatar
I second that. Also be sure not to break the drill bit in the bolt.
Old Oct 14, 2006 | 12:50 PM
Doctorturbo's Avatar
GOT BOOST!
If you've never done this before, I HIGHLY suggest you have a shop do this. The smaller the screw the easier it is to screw it up. Once it's drilled off center, or if you break the EZ-out off your really done then.
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
