Kazuma 50 - Clicking sound when trying to start
Old Oct 15, 2006 | 12:11 AM
cajunatv123's Avatar
Default Kazuma 50 - Clicking sound when trying to start
when I press the start button.. All I get is a clicking sound. Is this the starter?
Old Oct 16, 2006 | 08:47 PM
toolguy454's Avatar
Generally it is the starter.
You can verify this by taking the positive lead off the starter itself and hooking it to a test light.
Then press the starter button and if it lights up the solonoid is working and the starter is bad.
Old Oct 16, 2006 | 11:40 PM
smb05's Avatar
cajunatv123,
Start with the battery first. I noticed you didn't mention anything about your battery. Make sure the battery has a good charge, also you want to make sure that the battery is able to hold a load under starting conditions. Some of the Chinese batteries do not last that long and some do. Your local auto parts or repair shop should be able to load test the battery for.
SB.
Old Oct 16, 2006 | 11:48 PM
Scott3710's Avatar
I had the same problem and was thinking batter, but I tested the battery and it was good. I found push button switch was acting wierd. I pressed the thing about 50times and it finally worked and never had the problem come back. I am assuming it was the switch, but not 100% sure.
Did you try bypassing the switch to see if you can start it?
Old Oct 17, 2006 | 12:22 AM
Does anyone know the voltage of the batteries. I also have the Falcon 110, and was gonna try to start it by connecting this battery. But, didnt want to damage and of the electical components?
Old Oct 17, 2006 | 12:24 AM
The only thing written on the Battery is GT5-3. It is also a small battery.
Old Oct 17, 2006 | 10:20 PM
2manytoys's Avatar
It is a 12v battery. You can charge it and see if it will take a charge. You can also test the voltage of the battery to see if it is dead or not. The biggest problems with the 50 is the starters will go bad. Depending on how old it is may have the old style starter. The new ones are improved. You can get a starter from raceway atv.
Mkp
Mar 28, 2020 03:50 AM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
bbehrendt
May 28, 2015 09:25 AM
1000gade
May 27, 2015 12:37 PM
RoostKing
16
Jul 6, 2000 10:45 AM
