Disk pads
Old Oct 15, 2006 | 08:56 PM
Karlwashere's Avatar
Default Disk pads
I just replaced the rear bearings on my Raptor. I needed to replace the rear brake pads as well so I'm working on that know. I'm having trouble getting the piston all the way down. I'm using a 6" c-clamp to press it in and I've tried the drain some brake fluid but it won't go the last 3/16th of a inch. Anyone have any tips or tricks??
Old Oct 15, 2006 | 09:37 PM
lerea3's Avatar
Default Disk pads
Did you loosen the brake caliper bleed screw? The piston should return all the way back when it's loosened.
Old Oct 15, 2006 | 10:37 PM
recon99's Avatar
Default Disk pads
I bet it's that annoying parking brake holding the pistion in. Back out the adjustment bolt on that thing and you'll be golden.
Old Oct 15, 2006 | 10:58 PM
Default Disk pads
I tried the bleed screw, I also tried moving the parking brake lever back as far as it will go but I'll have too look at that again.
Old Oct 15, 2006 | 11:18 PM
recon99's Avatar
Default Disk pads
just moving the lever won't do the trick, you actually have to loosen the lock nut and back the adjusting bolt out of the caliper. As the brake pads wear you have to run that bolt in more for the parking brake to work, therefore when you put thicker pads in you'll have to move that bolt back out, or it'll prevent the piston from sliding back in. It's a poor system, that's why so many sport quads have the parking brake systems removed completely.
Old Oct 15, 2006 | 11:24 PM
Default Disk pads
Yeah I"ve never moved that bolt before but I'll try it tomarow
Old Oct 16, 2006 | 09:52 AM
GlennJ's Avatar
Default Disk pads
I agree with removing the parking brake. I had the same problem on my Wolverine...I could not install the caliper. Once I removed the parking brake, it was good to go.
That parking brake set up is something that was designed in the 1980's; my three wheeler had a very similar set up. With all the advances over the last 20+ years, you think they would have didtched that craptastic setup in favor of something more reliable.
toonces
Aug 21, 2015 01:19 PM
WilliamBos
Jun 30, 2015 09:38 PM
UPLou
Jun 7, 2015 09:42 AM
armyman
Nov 21, 1999 11:22 PM
