hole in sunl engine - anyone else
Old Oct 16, 2006 | 12:34 AM
rsplash40's Avatar
Default hole in sunl engine - anyone else
Ok, my kids sunl90 broke the two tubes everyone else seems to be breaking. Sometime between when I rolled it in the garage to fix, to the time it rolled out this hole appeared in the head of the engine:
Hole in engine.
Anyone else had this happen? I was working on the other end of the quad, and its a tight spot to get anything into to hit that area with. Especially inbetween the fins.
Any suggestions how to fix?
Old Oct 16, 2006 | 12:44 AM
smb05's Avatar
rsplash40,
Looks like your going to need a new head. Call Raceway they will set you up. Or you could try your dealer.
Good Luck.
SB.
Old Oct 16, 2006 | 01:06 AM
Scooter86's Avatar
Knows Old ATV Questions!
Shnikeys! Where did the peices go? Looks like a good weekend project for sure.
Old Oct 16, 2006 | 10:11 AM
billl2099's Avatar
another sunl bites the dust, looks like maybe a valve broke and the piston push it out the head, not worth buying parts for
Old Oct 16, 2006 | 12:52 PM
rsplash40's Avatar
I hadn't thought about the valve...however, it does run... found the hole while it was running..couldnt figure out why it was so loud.... my dealer is long gone.
Old Oct 16, 2006 | 02:22 PM
LaPurr's Avatar
If it still runs, and it hasnt caused any engine damage that you are aware of, see about sticking some JB weld on it for a SHORT term fix. Ride it around a bit, and if everything works out with it. You can get the JB weld removed, and try going to a weld shop and filling in the hole and hope no liquid gets inside the case area. Thats what I would do for a Cheap fix for a Cheap quad.
Old Oct 16, 2006 | 07:41 PM
billl2099's Avatar
if it still runs, then its a cooling fin at the exhaust port broke off , take off the exhaust pipe and see iif the hole goes from exhaust thru the hole i agree with laparr, just fill it with jb weld, if thats the case.
ghost civic
Jul 27, 2015 03:15 AM
bpegram84
Jul 22, 2015 08:15 AM
bpegram84
Jul 22, 2015 08:12 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
Coryco
Jul 6, 2015 07:30 PM
