700r valve clearance??? Need some info....
Originally posted by: ka24de
Intake .09-.13mm
Exhaust .16-.20mm
TDC Compression stroke (cold)
Intake .09-.13mm
Exhaust .16-.20mm
Any ideas????
did you check the clearance b4 adjusting? most times the valves get tight after you get a few hours on it. so you probably had to loosen them up a little right? that would make them a little louder than what they were b4.
I have an 09 700r. The valves were set at 10mm intake and 8mm exhaust. Thus was before I adjusted them to 10mm intake and 12mm exhaust. And the ticking becbece louder.
A "friend" told me to set them at 8mm intake and 10mm exhaust. Was told this would quite them down.
