reverse speed limiter
Old Oct 17, 2006 | 11:35 AM
mudmedic's Avatar
Default reverse speed limiter
how do you bypass t he reverse speed limter on a 2004 Yamaha Bruin? i have tried locating the green and white wire however I located (2) green and white wires on the same plug. I thought the procedure would be the same as for all Yamahas however it appears that the plugs are different and the green and white wires appear to look the same. Any help would be greatly appreciated,,
Old Oct 17, 2006 | 11:52 AM
squeege's Avatar
What plug, where? More info!
Old Oct 17, 2006 | 03:18 PM
mudmedic's Avatar
the plug under the left fuel tank cover...it has four wires going into it and (2) OF THE (4) are green and white. everything i have read says that the plug for the reverse limiter is located in this location and the above plug is the only one there.
Old Oct 17, 2006 | 03:39 PM
squeege's Avatar
I would cut the tape and that back to have a real good look.....I'm not sure about yours but mine had only one green/ white stripe wire in that location...
Steeldon
Sep 9, 2015 09:38 AM
poutlaw525
Sep 9, 2015 03:19 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
