Need help!! 300ex
Old Oct 17, 2006 | 06:04 PM
mh53's Avatar
Default Need help!! 300ex
hey guys my 01 300ex has been sitting for a while. it starts right up but spotters at higher rpms any suggestions
Old Oct 17, 2006 | 06:47 PM
bombrider04's Avatar
if it is staying at high rpms and you haven't riden it for a while i would clean out the carb since it has been sitting with gas in it for a while and make sure the cable and everything is lubed up and ready to ride since you haven't ridden it for a while
Old Oct 17, 2006 | 09:19 PM
JimmyHoffa's Avatar
Good word. More specifically, check your jets and make sure there's no buildup in their important parts. Your spark plug should readily inform you as to how the fuel system is behaving in regards to the upper RPM range. Just run it out (for a short period) and check the plug. The more soot/general depositing that is on the plug, the richer it is. So if your plug is bony white and perfectly clean, check the main jet. (hopefully, that would also bring about your concern for the rest of the fuel system, and your concience would force you to give it the once-over) Probably clogged/deposit-tapered. If not, shoot me another post. or a PM. I don't care. I know so much about that bike and have so much seat time I've gotten bored and am buying a different one.
Old Oct 17, 2006 | 11:00 PM
mh53's Avatar
great thanks for the info. i while get back with you
Old Oct 17, 2006 | 11:14 PM
alright good luck and let us know how you make out
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
