Clutch Lever Raptor 700
Old Oct 22, 2006 | 01:40 AM
Soccermike26's Avatar
Default Clutch Lever Raptor 700
Can someone tell me what the switch on the Clutch lever is? I am trying to put on an ASV clutch lever and there is some type of switch rider side of the clutch cable. If this is important, how do I get rid of it or how do I make it work with my lever? Thanks for any help
Old Oct 24, 2006 | 12:35 AM
chip700r's Avatar
Are you only changing the lever? I changed mine to moose racing levers
Old Oct 24, 2006 | 12:56 AM
Yeah, i am just changing the lever but there is a switch in the stock clutch lever that I'm not sure what it does or what to do with it
Old Oct 24, 2006 | 11:39 PM
chip700r's Avatar
you must be changing your perch along with ur levers,sorry i cant help u there....I only changed my levers to the ones with the molded rubber grips on them.
Old Oct 24, 2006 | 11:52 PM
Yeah, I'm changing the perch too. Apparently its not a Hot Start. It has something to do with starting it in gear. I guess if you don't have the clutch pulled in it won't even attempt start in gear. This is the switch that controls that. If you happen to run into this, or anyone else that reads this. The Yamaha deal said you can loop it by removing the switch and connecting the wires to one another. Hope that works.
STLyamwar
Jul 25, 2020 04:44 AM
Aug 21, 2015 01:23 PM
Polarisman1123
Aug 3, 2015 02:08 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
brad wheeler
Jul 13, 2015 11:19 PM
