02 Raptor 660 No Spark
Old Oct 22, 2006 | 10:55 PM
mudrun's Avatar
Default 02 Raptor 660 No Spark
My sons 660 Raptor backfires from the muffler every once in a while tring to start it. I pulled the plug to check the spark. NO spark I have tried other plugs that he has and the same thing, I see a spark when I let off the start button. The plug is grounded against the exhaust bolt . Anyone have any ideas. Thanks
Old Oct 25, 2006 | 09:36 PM
mudrun's Avatar
I called the yamaha dealer(repair shop) on my problem with the spark. They told me to get a new plug!
I had three plugs that I was tring and all three had the same results, But I picked up a new one just to try. The same problem NO SPARK the only spark I get is at the end of the cranking when I take my finger off the start button. The Battery drains down quickly. I have put my battery booster on it,to give it a little extra shot. But the battery with meter is showing 11.8 DC Volts before i add the charger. Things just don't add up could anyone help with this problem. Also could this be the Rectifier Regulator. or the coil.. Has anyone had this before or heard of this.
Thanks
Old Oct 25, 2006 | 11:11 PM
lmess89's Avatar
Unplug your rectifier and see if it will start. If it does its probably your stator. Thats what was wrong with mine anyway.
Old Oct 26, 2006 | 07:25 PM
mudrun's Avatar
is the rectifier in the back of the machine. back behind the brake light. I am not sure where the rectifer is at. Thanks.
Old Oct 27, 2006 | 07:22 PM
mudrun's Avatar
Ok I unpluged the rectifier and had real good spark. Put the plug in and it started up, So the way it sounds,now the stator in the problem correct. if you read this please get back to me. Thanks for your help.
Old Oct 27, 2006 | 07:39 PM
bombrider04's Avatar
My guess would be that the rectifier is bad because I don't understand how unplugging it would make the stator bad can some1 elaborate please
Old Oct 28, 2006 | 03:59 AM
2FAST4URASS's Avatar
Just chat with this guy he will reply fast or just call him i bet he can help you figure out your problem' hes a great guy to do business with. http://www.rickystator.com/
Old Oct 28, 2006 | 04:11 AM
OH AND if i had to guess whats wrong with it id say the pick up coil. http://www.rickystator.com/pages/Yam...ckup_coil.html And as of the rectifer its under the back fender same side as the shifter but i highly doubt that is your prob or will help by unpluging it rick told me when i had issues with mine to unplug the stator theres two sets of wires unplug the three white one if its fires you whole stator is bad.
Old Oct 28, 2006 | 03:42 PM
mudrun's Avatar
The rectifier on this raptor is located between the tail light and the battery on the outside of the machine. With it plugged in I have no spark until I release the start button then I do get a little spark. When I diconected the wire harness from the rectifier I had real good spark. I put the plug back in the machine and it started up. Had a lot of gas sitting in the engine but that burnt out . So with this in mind Do you think the problem is in where?is there any test that I can do to track the real problem.
Old Oct 31, 2006 | 09:17 PM
lmess89's Avatar
Its the stator. Had the exact same problem on mine.
STLyamwar
Jul 25, 2020 04:44 AM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
