Im new and need help with my 686 raptor
Old Oct 23, 2006 | 07:08 AM
TDK's Avatar
TDK
Default Im new and need help with my 686 raptor
The bike has oversized valves, stage 2 hot cam, kibbelwhite valve springs, 102 mm 12.5 to 1 je piston, and an open air filter and a crappy t4 pro circuit exhaust. Basically it won't start to easy when cold and when its warm it will not cruise a steady rpm without sputtering and stumbling. But it runs real strong when going full throttle. And If it is hot and I kill it getting it to start again is almost impossible without letting it sit for about 20 minutes or more. But then it starts right up. By the way stock carbs with 190, and 195 mains with 27.5 pilots. When i first start it up it runns great But after it has been run for a while maby10 to 15 minutes it won't cruise or start back up. But it still will run like a raped ape at wot. Any help would be greatly appreciated. Thanks, Chad
Old Oct 23, 2006 | 07:48 AM
RaptorRRC's Avatar
Give me a call if you want. I have a few ideas to help you out but it would take me forever to type it. 870-542-5133
Old Oct 23, 2006 | 04:18 PM
azdave's Avatar
Have you adjusted the valves? Sounds like they are real tight.... ?
Old Nov 22, 2006 | 12:53 AM
Iceman121887's Avatar
hi names Kevin and got some serious issues with my 660 or now 673 raptor and read how you were tryin to help another guy out was wonderin if i could get some help it would be greatly appreciated. ive got a 2001 660 raptor like i said its now a 673 with a 10.1 piston ive also got a stage 1 hotcam, racing valve springs, larger output stator, racing coil, trinity stage 4 full exhaust, k&n air filter, with no airbox lid, and a Sparks brand voltage regulator. the trinity exhaust came with several different jets but it wasnt much help on jetting ive tried all the jets and none seem to make it run right as of now i have 165 and 170 main jets in it the four wheeler cranks fine almost too good compared to my buddies stocker which is cold natured as hell mine fires right up no matter how cold it is but when i go to accellerate the four wheeler starts to cut out above say half throttle. sorry for such a long message like i said any help would be appreciated
Old Nov 22, 2006 | 12:55 AM
fastblaster00's Avatar
idk but arnt those jets a lil to small?
Old Nov 22, 2006 | 12:54 PM
warwgn's Avatar
jetting link
Old Nov 22, 2006 | 05:05 PM
azdave's Avatar
You are definately too lean. I had bigger jets than that in my stock bike with Pipe and filter.
Old Nov 23, 2006 | 12:03 AM
AustinONeal's Avatar
call raptorrrc he can fix u up TRUST ME,
Hey bob did u ever get jasons piston?
Old Nov 23, 2006 | 12:46 PM
DriverDoyle's Avatar
Austin is right...give bob a call..he will hook you up..
Old Nov 26, 2006 | 04:47 AM
thanks guys anybody know the best time to call raptorrcc im out on the east coast so didnt want to call him in the middle of the night or somin
