Sluggish Predator 90 warm up
Old Oct 24, 2006 | 03:07 AM
mxzer's Avatar
Default Sluggish Predator 90 warm up
I've got a '06 Predator 90 that has had the first pre-mixed tank run through and is now on second tank of straight 90 octane. Even though it's stored inside, the warm up is very sluggish. It requires a choke to start and then slowly let off choke while maintaining throttle. After 30 seconds of medium reving and then put in gear, it is very sluggish and sometimes stalls out. Once you can get it moving with choke off and get a minute or so on it, it's fine. Warm up should not be that bad in those conditions. Any ideas? It's certaintly not a rotax 2-stroke ;-)
Old Oct 24, 2006 | 01:26 PM
oldyeller's Avatar
What temperature are we talking ?...It might need a little tweaking of the air screw on the carb..
Old Oct 24, 2006 | 01:41 PM
Evasiveone's Avatar
A minute or two warm up time does not sound bad on a carb engine.
Todays fuel injected/computer controlled engines have us spoiled. I remember many a days growing up sputtering along in cars/trucks of old waiting several blocks/minutes for it to warm up.
Higher octane fuels can also lead to hard start conditions in cold weather. Remember higher octane just means the fuels ability to resist burning, which also means in a cold low compression engine it can lead to a hard start condition.
Old Oct 24, 2006 | 01:44 PM
mxzer's Avatar
Garage is kept at 70 degrees and outside temp is has been about 50 on average. It's started in the garage, so it's pretty warm to start with.
Old Oct 24, 2006 | 01:47 PM
mxzer's Avatar
I've had many carb 2-strokes in the same conditions that do not exhibit this problem. I hear you on the fuel injection, but all of my machines still live in the world of carbs :-)
squeege's Avatar
What does straight 90 octane mean? You have the auto oil injection hooked up right?
Old Oct 24, 2006 | 01:48 PM
mxzer's Avatar
"straight 90 octane" means no oil pre-mixed into the fuel.....it's using the oil injection only.
Old Oct 24, 2006 | 02:03 PM
Blazer25's Avatar
I'd have to agree with oldyeller. My daughter's 90 doesn't have problems idling once it has been started. Usually when the quad has a hard time idling, the first thing you want to do is try adjusting the air screw.
Old Oct 24, 2006 | 02:09 PM
mxzer's Avatar
I'll give the air screw a try tonight.
Old Oct 25, 2006 | 05:31 PM
mxzer's Avatar
Well, last night when I started it, it ran fine this time. Did bump up the screw a tad and will try it some more over the next couple days.
IMLN
Sep 28, 2015 03:32 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Elkaholic
Sep 6, 2015 02:44 PM
