How do you know if a spark/primary coil is bad?
Old Oct 24, 2006 | 08:18 PM
Smitty12345's Avatar
Default How do you know if a spark/primary coil is bad?
I still have no fire from a 185S three wheeler..primary stator coil in it was bad, you could see a broken wire. Now how do I OHM out the "good used one" to see if it is good. I have put it in and still have no spark.. With the stator assembly removed and the meter set on X1X I get exactly 500 on the scale. This is reading from the single red wire to the base of the stator assembly.. Seems to me that it reads good. I tried another CDI box and spark plug coil and ignition pickup from a running bike and still no spark..Spark advance in the pulse generator assembly was gummed up and did not float freely. I cleaned all this up good and it now works free. Suggestions Please.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Joe454
Nov 20, 2020 01:19 PM
kbazzy
Sep 26, 2015 11:26 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
