Question about piston and rings on 450s? Help!
Old Oct 27, 2006 | 01:35 PM
slwhite79's Avatar
Default Question about piston and rings on 450s? Help!
I have some knocking noise coming from my engine and the wheeler smokes as well so from what i can gather the piston rings are probably worn thus creating slap from the piston and the smoke being created as well. There is no water in gas so this is my conclusion on noise.
Anyways, i am doing this myself and am about to order some new rings, maybe a piston to, but how do i know which rings to get. I see all over ebay and elsewhere rings for a 450s (2004) that fit the factory specs but there are so many differences in the rings that all claim to fit the stock oem piston. Like .90mm, .025mm, .075mm. Not sure if these numbers are correct, but will all the rings work, should there be a certain size or measurement i am looking for, etc? Thanks
Old Oct 27, 2006 | 02:31 PM
PaulH's Avatar
I'd say it's best to order it from here to make sure you get the right parts...
http://www.oem-hondaparts.com/
Old Oct 28, 2006 | 02:02 PM
bombrider04's Avatar
well you will want to measure the size of the piston and the bore using a micrometer or vernier caliper and once you get the piston and rings ect you will want to check the ring gap by putting them into the cyclinder by themselves without the piston...you will also need to get a ring compressor along with a torque wrench,snap ring pliers, feeler gauge, and spring compressors for the valves
STLyamwar
Jul 25, 2020 04:44 AM
robert301972robert
Aug 30, 2015 11:34 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
clsharky
Jul 13, 2015 02:07 PM
