450ES Electrical Problem ... HELP
Old Dec 7, 2000 | 11:27 PM
Kosaic's Avatar
I have a 2000 450ES and have been having the foillowing problem since I bought it in April/2000 . When I'm driving along the dash blanks out for approx. 1-2 seconds , and when it comes back on , the clock and trip have been reset. It doesnt seem to happen for any specific reason, just seems to happen at random. Whether the bike is hot/cold , wet/dry, it doesnt matter. It can even happen when the bike is sitting idle. The dealer has replaced just about every part you can imagine ( cdi,sensors,dash,etc... ) and cannot seem to get it fixed. Bike works fine otherwise but this is getting so annoying you have no idea ! I bought the bike brand new.
If anyone out there is having the same problems , please let me know ot let me know how you resolved it. Thanks.
2000 450ES, Supertrapp IDS pipe, K&N jets, K&N Filter, Maxxis 26" Mudbugs, OxLite Bush Guards, Warn 2500lb winch, Shockwears, Hot Grips, Hot Thumb, 36.5W Halogen Headlamps ......
Old Dec 8, 2000 | 10:35 AM
Thor's Avatar
Have you replaced the lithium (back-up) battery in the speedometer pod yet?
Think of the bright side. You will have the lowest mileage 450 ES around!!
Old Dec 8, 2000 | 12:33 PM
Kosaic's Avatar
The actual speedo doesnt reset , only the trip and clock. And yes , they replaced the whole dash at 2000km and I now have 200km on the bike ! )
Old Dec 8, 2000 | 03:58 PM
BigRed450's Avatar
Sounds like the computer to me. That is what controls the system and I believe the mileage. Although it could be as simple as a short...
Good Luck.....keep us posted.
Old Dec 8, 2000 | 04:46 PM
bowtiepu's Avatar
i know you said the dealer have checked or replaced everything..i would get the service manual and trace all the grounds thru out the quad..theres a good chance you have a bad ground,if you have a bad,loose ground it can cause these symptoms..i know in autos we have had alot of computer problems caused by bad grounds..if its not a bad ground,trace all the wires to all the plug connectors and check them as well as look for any wires damaged or pinched..good luck
Old Dec 8, 2000 | 05:27 PM
Kosaic's Avatar
The dealer "said" they checked all the connections/sensors/grounds. I have had it back 5 times now with this very problem. I guess I may have to find it myself it seems. I was hoping someone else suffered from a similiar problem so I could at least know where to start. ( not that I wish this on anyone else !
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
