Clutch cable...when to replace?
Old Oct 28, 2006 | 05:12 PM
wrestleu's Avatar
Default Clutch cable...when to replace?
How do you know for certain if it is time to replace the clutch cable? Or more importantly how do you adjust it down by the motor. My Clymers doesn't really do a very good job of describing it.
The reason I ask is because my lever is really really sloppy, way too much play. And before I took it in to have some work done, it was just right. He said he adjusted it so it would have the recommended amount of play, well now it has way too much play and I can't for the life of me figure out how to tighten it up.
Thanks.
Old Oct 29, 2006 | 01:06 AM
JkAss's Avatar
You can adjust it at the case, the lever or both. When you can no longer adjust with the cable that is when you replace it, but you have to make sure it is not the clutch itself that is the problem. If you replace the cable and still can't adjust it right, it might be time for a clutch replacement.
Old Oct 29, 2006 | 02:43 PM
wrestleu's Avatar
exactly how do you adjust it on the side case? I'm a little perplexed on that one.
thanks
Old Oct 30, 2006 | 11:57 AM
JkAss's Avatar
You should be able to backoff the jam nut and adjust the cable at the case. The cable should be threaded at the case. If this isn't how yours is setup then you might not be able to adjust it in both places.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
