more torque help
Old Oct 29, 2006 | 01:07 AM
marksduramax's Avatar
Default more torque help
I have a 99 scambler 500 4x4... I use it only for hunting.. My question is how can i get more torque out of it.I dont need alot of speed going up the hills . right now when i go up steep i got to go kinda fast... So what can i do?
Old Oct 29, 2006 | 09:11 AM
ftwflh's Avatar
Start by setting your secondary at 2-2 and see if that helps.Then you may think about either an EPI pink or Dalton blue primary spring and then if you want more lowend go with a litle heavier shift weights.
Old Oct 29, 2006 | 12:28 PM
Ok im losts what is all that?
Old Oct 29, 2006 | 06:02 PM
ftwflh's Avatar
You need to fine tune your clutches for how you ride.
The springs and weights control how and when your belt hooks up to pull the wheels.
dannytas
Sep 26, 2017 06:31 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
01ssls1
Sep 22, 2015 06:50 AM
raman8tor
Sep 20, 2015 07:35 AM
Steeldon
Sep 9, 2015 09:38 AM
