Mudzillas?
Old Oct 29, 2006 | 06:11 AM
DAVEY300's Avatar
Default Mudzillas?
Before i get them will the 28 zillas fit on the factory 800 allum rims?
thanks davey!
Old Oct 29, 2006 | 09:33 AM
SPORTSMAN70003's Avatar
Default Mudzillas?
Yeah they fit on the rims. You will need spacers for the front so the tires don't rub the tierod.
Old Oct 29, 2006 | 09:48 PM
Instigater's Avatar
Default Mudzillas?
I had 27" Mudzilla's on my 800 with stock clutch. I was in 2 mudholes that The big 800 could not turn the 27's over. 28's would be worse. If I may recommend, get a clutch kit. You will need to get the bottom end back that you'll lose with the 28's! I eventually put 28" zilla's on it, but I put a Heel Clicker clutch kit in at the same time. I was able to do wheelies again![img]i/expressions/face-icon-small-happy.gif[/img] I loved the low end power with the Mudzilla's, they are best trail/mud tire, atleast in my opinion!
Old Oct 30, 2006 | 05:59 AM
DAVEY300's Avatar
Default Mudzillas?
What does the heel clicker consist of ! Is it a diy job or dealership job?
Thanks for the info!
davey
Old Oct 30, 2006 | 10:21 AM
Instigater's Avatar
Default Mudzillas?
Totally DIY forthe 800. The 700 "MAY" require some dealer help! The Heel Clicker is an adjustable type clutch spring setup. You can adjust the spring tension and flyweights. Contact Floodrunner for a kit, somewher in the range of $180!
Fishy
Mar 27, 2006 03:57 PM
bwm87
Dec 11, 2004 06:32 PM
TylerZR2
Jun 8, 2004 02:22 AM
TraxterMax
Mar 15, 2004 08:38 PM
nyroc
Dec 7, 2002 11:42 PM
