Modifing raptor wiring harness
Old Nov 4, 2006 | 01:02 PM
TDK's Avatar
TDK
Default Modifing raptor wiring harness
Basically I am wanting to make my look super clean and I have been doing some weight reduction. Is there a way to strip the wiring harness down to just what the motor neeeds to run. I would like to remove all the brake sensors and lights and move the key switch to under the seat or something. Some of the drag raptors that I have seen looked like they didn't have very much wiring at all. Can it be done. Any info would be greatly appreciated. Thanks, TDK
Old Nov 4, 2006 | 07:10 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
You bet it can be done......
I have mine stripped down to just the CDI, rectifier, Kill switch and start button THAT'S IT. Stator still charges battery, starter works excellent........
Old Nov 5, 2006 | 12:13 AM
TDK's Avatar
TDK
Is it as easy as just splitting it and pulling those wires out, or is there other stuff involved. I would like to do this, but I don't want to screw it up. Did it clean up the look of the bike alot as well. Thanks, TDK
Old Nov 5, 2006 | 12:25 AM
TDK's Avatar
TDK
I just looked at the pics of your drag raptor and the thig is awesome. Do you still have a thermostat on the cooling system.
Old Nov 5, 2006 | 03:05 AM
Yes it is that easy........You need a Schematic of the wiring harness. Go thru and eliminate what ya don't need. I saved about 8 lbs. of weight form eliminating unneeded wire.....PM your E-Mail address and I'll send you some pics of what I've done.
It's all gone NO fan, No thermostat and all that wiring has been eliminated.........
Old Nov 5, 2006 | 01:39 PM
TDK's Avatar
TDK
Will my thermostat work with out the wires going to it. I still want to have a fan so I can ride the bike for extended periods of time. I want a drag bike that I can still ride for several hours at a time. What would you suggest I do with the cooling system. Thanks, TDK
Old Nov 5, 2006 | 04:31 PM
TDK E-Mail sent
I don't have any problems running without the fan & thermostat. My inline temp gauge reads 185* cruzing around in 90* temps.
If I make 4 to 5 back to back 300' passes then it runs up to 200*- 210* Thats when I shut it down and let er cool.
Old Nov 5, 2006 | 06:36 PM
TDK's Avatar
TDK
Wow that is awesome how you have that set up. Thanks for the pics
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
COFatboy
May 2, 2020 12:06 AM
black_thunder
Jul 22, 2015 06:01 PM
chammerbeck
Jul 17, 2015 08:06 AM
ranvette
Jul 4, 2015 06:13 PM
