Tire chains for plowing snow?
My answer is also NO.All my 4x4 quads [3 of them] have had snow plows,I have very easily plowed a foot of snow the approximate length of 100 ft at one time without the need for chains.You just need to take smaller bites with the plow blade in the real heavy accumulated snow,
Bill
Bill
Guys would your opinion be the same for plowing on ice? I was all set to go out and buy a set of chains for my 450ES because I was planning on using it to plow off drag strips on the local lake. Maybe I can save a few $$ here.
Thanks for any info.
Temp
Temp
If you are plowing snow on the ice you will should get good traction without chains. The snow leaves a rough surface on the ice, but if the ice is real shiny under the snow like a freshly flooded rink you may need chains.
