ave to change a tire, how big of a mess you have to deal with.Thanks,Slime or NO Slime
Old Nov 10, 2006 | 08:34 AM
SherpaT350's Avatar
Default ave to change a tire, how big of a mess you have to deal with.Thanks,Slime or NO Slime
Just wondering if you guys use slime in your tires and what are the pros or cons ? I am wondering when you do h
Old Nov 10, 2006 | 12:00 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
My personal experiences with Slime have been negative. It will eventually dry up, and just leave a crust on the inside of the tire. But hey, no mess when you pull the tire off.......but no flat protection either!
I now use Fix-a-Flat, and it has never let me down. There is of course going to be some mess when you break the bead.
Old Nov 11, 2006 | 09:34 AM
SherpaT350's Avatar
It says on the container that it will not harden , maybe this stuff has been redesigned since you last used it ? I am just wondering how big of a mess it makes when you do have to change the tires ? Does the fix a flat work just as good or better ?
Thanks,
D.
Old Nov 11, 2006 | 10:20 AM
Red Rider
Think about this.........Slime is based on the fact that the fibers it contains get forced into the hole by the escaping air pressure. This might work well enough in a 60 psi truck tire, but not so well on a quad tire with a mere 4 psi of pressure!
And, with any liquid you put into your tires, you have to also consider rim corrosion issues..........
Old Nov 11, 2006 | 09:37 PM
mykool61679's Avatar
i used it on my stock 2- ply tires, and it worked good for small punctures, like thorns and such. its easy to change the tires , its just liquid that washes off the rim. had it like that for a year!
Old Nov 11, 2006 | 09:46 PM
SherpaT350's Avatar
How about this stuff ?
http://www.motoworldracing.com/Quadb...e-Sealant.html
Thanks,
D.
Old Nov 12, 2006 | 12:26 AM
mucky's Avatar
tires with slime do seem to make a little mess if you have to remove them but it all washes off with water. i've had good luck with slime in my tires, its never dried in the tires as long as you have close to what they recomend in it. but remember slime wont seal a tire bead no matter how much is in it
toonces
Oct 16, 2019 12:11 PM
rcappie4
Jul 18, 2015 07:51 AM
Jul 15, 2015 02:07 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
