Rectifier with no airbox?
Old Nov 13, 2006 | 10:27 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
Default Rectifier with no airbox?
I did a search with no luck. For those of you that have removed the airbox, where did you put the rectifier? I looked up my FedEx tracking # and my Lectron is on the truck for delivery! So, I went out and started tearing it down, and was tring to think of where to put the rectifier.
Thanks for your help and suggestions,
Chris
Old Nov 13, 2006 | 10:54 AM
shmee's Avatar
mount it to the fender, under the seat. it will be upside down. right in the middle.
Old Nov 13, 2006 | 11:05 AM
Thanks shmee! That is about where I was thinking for now. I am making a bracket to mount another (total of 2 rectifiers) for the enduros and desert challenge. Not to many palces to put it, but there are some crafty people on here so I figured I would ask to see what others have done with it.
FedEx just dropped of the Lectron!! US to Dubai in 3 days!!
Chris
Old Nov 13, 2006 | 11:18 AM
Hightower's Avatar
I used the same hole the airbox mounted to, the one on the right side by the starter solenoid. one 6mm bolt and lock nut thru this hole and one hole of the rectifier with rubber washer between them, and thru the other hole of the rectifier I slip a zip-tie and tie it to the subframe tubing with a rubber washer between them, the rubber washers you have left over from where it was mounted to the airbox. it looks factory this way, very clean.
Joe454
Nov 20, 2020 01:19 PM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
