Honda TRX 350 Wont Rev
Old Nov 13, 2006 | 02:09 PM
enviro's Avatar
Default Honda TRX 350 Wont Rev
Hi, I am trying to sort a 350 for a friend, It wont run unless the choke is pulled out, and missfires badly, any Ideas. Thanks enviro.
Old Nov 13, 2006 | 04:00 PM
jonnyboy5662's Avatar
first thing is try a new plug. I'm not sure why the quad would be fine then suddenly running really lean, but it could considering the choke richens the mixture, so try adjusting the idle mixture.
Old Nov 13, 2006 | 04:43 PM
enviro's Avatar
Thanks jonnyboy5662 I tried a plug from another machine ,but no change, the electrode is light brown in colour, I think that is o/k. Where is the adjustment to richen the mixture?.
Old Nov 13, 2006 | 06:41 PM
I assume you're talking about the rancher... I looked at a diagram of the carb online and it looks to be in on the bottom between the float bowl and the cylinder head. It's a small (brass I think) screw. Not sure what the stock setting is on that one. Screw it in and count how many turns it takes to reach the seated possition, remember this number in case this isnt the problem. Try adjusting it from there a quarter turn at a time. Warm the bike up first if you can with the choke on like you normally do before you do this.
Good luck
Old Nov 13, 2006 | 09:29 PM
twoodward15's Avatar
If it runs with the choke on then that tells me that it isn't getting enough gas. Lets start with the screen in the petcock. Clean that. Change or install an inline filter if possible. Clean your carb and see if it runs right then.
Old Nov 13, 2006 | 09:41 PM
speedblurr's Avatar
I'm new here, but our honda was doing the same thing 2 days ago. Last night I removed and cleaned the carb and it works like a champ! Hope this helps!!
Old Nov 13, 2006 | 09:44 PM
melloyello's Avatar
Did it happen to sit up for a while? Maybe the gas is bad and has clogged the jets a bit.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
rgjackson
Sep 17, 2015 11:21 AM
wendal
Sep 15, 2015 01:50 PM
Jason Campbell
Sep 7, 2015 02:25 PM
