K&N Power Lid help
Old Nov 16, 2006 | 12:02 PM
apny2nv's Avatar
Default K&N Power Lid help
Just purchased a new K&N X-treme power lid kit. The kit comes with a jet kit to install with the lid. I'm wondering if anyone here has one installed. My 03 660 Raptor currently has a full Yoshi exhaust with a K&N filter and has already been jetted for those to mods and runs perfect. My question is will I need to rejet to compensate for the new lid, or will the current jets that have been set up for the pipe & air filter be ok, and what are the signs of the bike running lean if I run the bike with the lid and the current jets?
Old Nov 16, 2006 | 01:53 PM
trapland's Avatar
Take it back quick! I have the exact setup as you 03le, full yosh, k&n, powerlid. Unless you need the protection of the lid, you WILL lose power. If you are still determined to use it (I do for mudding), IGNORE k&n's recommendations. They could not be farther off.
If you are jetted for your setup with no lid, drop one size on your mains and try 1/4 turn leaner on your fuel screws.
If you are jetted for the stock lid on, go up one size on mains and 1/4 turn richer.
The needle should be fine.
I'm at 155/160, 3rd clip, 3-1/2 turns at 60 degrees and 300 feet elevation.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
