yfz450 guys... i need some help
Old Nov 16, 2006 | 03:48 PM
colt2245p's Avatar
Default yfz450 guys... i need some help
i have several friends with yfzs.. varying in years and they all seem to have the same problem. when you crack the throttle off an idle they die!!! some of these are modded some are stock. they all run very well at all other throttle ranges. we have put the accelerator pump cover on a couple but it didnt really help much. jetting has helped the most. what have you done to yours to correct this. is there a fix? thanks for the help
Old Nov 17, 2006 | 10:28 AM
colt2245p's Avatar
no one has this problem????????
Old Nov 17, 2006 | 12:19 PM
raptorchick's Avatar
Personally, I've never had that problem. As long as I let her warm up, the only time it will die is due to user error. [img]i/expressions/face-icon-small-blush.gif[/img]
Old Nov 17, 2006 | 01:40 PM
GITRDUN's Avatar
You need a smaller leak jet for your accelerator pump. Its a common problem on the YFZ450. Go to YFZ central forums, theres posts there about how to fix it and where to get the leak jet. Also, dont expect your dealer to know what your talking about, most of them dont even know what the leak jet is. After reading your ENTIRE post though, if the pump cover didnt fix it the leak jet might not either. Mine got much better when i switched to the GYTR jet needle, i used to have the JD needle and it had that problem bad.
Old Nov 17, 2006 | 09:02 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Here's what was wrong with mine...........
There's a switch in the thumb throttle AND a switch in the carb throttle housing..........BOTH switches have to open OR close at the same time (i think it's part of, OR the T.O.R.S. system) Look at the switches and see what I'm talking about........
ALL I had to do is readjust the throttle cable and problem solved......[img]i/expressions/face-icon-small-smile.gif[/img]
Old Nov 17, 2006 | 09:15 PM
Vulcan700's Avatar
I had the same problem and it was all jetting. Installed new exhaust pipe did that new jet then changed air filter system started all over. I took the bike down to a race shop here they put it on a dyno and fixed the jetting runs great now. It will stall if it is not warmed up. If you don't have a dyno keep changing the jets till you get the right match for the mods
GITRDUN
is right on track IMO
Sep 23, 2015 06:23 AM
VRRRRT
Jun 20, 2015 03:47 PM
250R4LIFE
Jul 2, 2003 04:13 AM
brad650
Jun 12, 2003 12:34 PM
BigBlack
Jun 7, 2003 06:51 PM
