'71 atc 90 spark problems, help!
Old Nov 17, 2006 | 03:22 PM
dannygraves's Avatar
Default '71 atc 90 spark problems, help!
Hi, I recently acquired a '71 honda atc 90 (us90) and it isn't putting out any spark and I just wanted some advice before I start buying parts. The alternator is putting out about 30 volts a/c (not sure if thats too muhc, maybe there is a problem there).
the points look good but with my ohm meter on the green wire and the ground, it appears to be grounded all the time even when there is a gap in the points. I tried disconnecting the green wire since it looks like it the points open when it is supposed to spark and I'm still getting nothing. I want to think its the coil, but if the point wire is shorted, or the alternator is putting out too much voltage, I wouldn't want to burn up a new coil.
Any advice??
Thanks
Danny
Old Nov 18, 2006 | 02:59 PM
hondabuster's Avatar
You could ohm check the coil, to see if its good,
Id suspect the points first.
skinnyr6
Aug 25, 2023 02:18 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
